I bought the bike knowing the pgm III was damaged. The back cover was burnt in a small area and it doesnt operate the RC valves. I understand the valves should open and close at certain revs. Any info would be much appreciated.
Try this chap, i think he has one, 07941524339, ask for Alan. Good luck. _________________ Proud Father of , 05 ktm 400exc supermoto 2018 honda crf rx supermoto
Sometimes I guess they just fail. My RC valves are spotless and after letting my bike sit for extended periods as I was working away they just stopped working. Sent My PGM to Nick at 2 Stroke Racelab and problem solved. (With the RC valve anyway)...
Not sure if it would work, but when you fit the RC valve into the barrel mark the position on the actuator wheel when the RC valve is 2mm recessed. You can then tell where the RC valve is without removing the exhausts.
