Blown PGMIII News
Blown PGMIII News
Mon Jun 27, 2005 8:55 am » Post: #1 » Download Post
Here's an important note about why the PGM's blow.
Mostly the problem is related to the RC valves being dirty or too tightly adjusted, but I have just found that it can also be linked to a dodgy TPS.
A fractured wire obviously causing strange resistance readings killed the RC valve operation on a PGMIII. A new TPS solved the problem.
If you have PGM's blowing up and non moving servos check out the TPS.
Mon Jun 27, 2005 11:41 pm » Post: #2 » Download Post
Wasn't a dodgy T.P.S. the probable cause of death to two PGMIIs on the MC18 we were tampering with at Luke's place one afternoon Matt? Confused
Tue Jun 28, 2005 2:31 am » Post: #3 » Download Post
'Tis true brother Andrew. however, remember on that one that although the PGMII started smoking (scary!) the RC valve were still in operation. Wierd.
I think the answer to all this is that these bloody bikes are so ahead of their time (even the lowly MC18) that if you even just look at them from a funny angle they're likely to blow a fuse!
So I would say that in your regular maintenence schedule you should include inspection of the TPS among all other things. Check that the resistance slides up and down the scale smoothly and doesn't jump about. A squirt of WD40 or something might help keep any potential corrosion at bay. If in doubt, change it. I'm sure that they're easy to get hold of in good condition, used.
If it's gone to ruin already then it may not come back to life. I tried to ultrasonic one TPS in an attempt to resurrect it, but it had no effect.
Tue Jun 28, 2005 9:21 pm » Post: #4 » Download Post
Now you've made me mad. You know what you said matt! Wink
