Good nsr250 parts configuration ?
Vortex
Wed Apr 22, 2015 9:59 pm » Post: #1 » Download Post
Hello everyone, I need some advice on putting together a bike.
I haven't owned a 2T in 20 years but nostalgia drives me to get one now. I will not be racing the bike on a track, think of it more of a hobby project and a Sunday ride. My tech knowledge is limited so bear with my ignorance (I have gone only as far as swapping a cylinder/piston/rings).
I've met this guy who has a lot of parts from most models and I'm thinking of starting with a mc21 frame / gull arm rear fork, no fancy pro arm. However USDs would look nice, which would you recommend considering availability and price ? Also from a quick read I understand that swapping cylinder heads with mc18s that don't have an offset on the spark plug is better. Could you comment and recommend similar modifications or advice for my venture ? Much appreciated!
Alex.
foxmcscrooge
1996 Honda MC28 SE
Tue May 05, 2015 4:24 pm » Post: #2 » Download Post
Hi Alex,
I use my 28 as a road bike. These are my observations.
Many run RVF400 forks. Others have RS250 NX5 forks but they will cost you a pretty penny. Tyga do triples to suit both. They also do triples to suit the stock forks. I rebuilt my stock forks and run Tyga billet triples and to be honest I'm very happy with them. I really don't see any need to go to USD forks at all. You also lose steering lock. Rear shock is another story. I've been thinking about getting a fully adjustable Ohlins unit which is now available for the 21 and 28.
Many run the head from the rear cylinder on the front cylinder. You need a different radiator hose and an expensive stubby spark plug to clear the radiator. Others here may correct me if I'm wrong but you don't gain a lot of HP from it. For a road bike, not at all necessary unless you are chasing HP.
From my perspective best and cheapest gains performance-wise are wire splice (to delimit the ignition), decent exhaust (although I've heard told the 21 exhaust is pretty good; just heavy), make sure the engine is in good condition, airbox mods and good power valve cleaning/adjustment. All cheap with a 21 and you will end up with 60 plus HP with a virtually stock bike for no more effort than a re-jet.
With my 28, as well as the rather expensive HRC ignition that is needed for that model to delimit the ignition, I also installed billet exhaust manifolds, performance reed block and had some mild porting done. It's putting out a reliable low 60s HP running slightly rich. Radial front brake master cylinder (from a CBR1000RR as it accepts the same brake light switch) and braided brake lines are also a good upgrade. From there it's more and more money to chase less and less HP gains with less and less long term reliability.
Jim
Tue May 05, 2015 5:07 pm » Post: #3 » Download Post
Jim pretty much nailed that! Wink
