MC18 track bike help
triggerrogers
Mon Jul 20, 2015 5:29 pm » Post: #1 » Download Post
I have recently bought a MC18 track bike and currently giving it a thorough check over before hopefully giving it a run at Snetterton next week.
After removing the carbs I see there is a pipe in the crankcase above the reed blocks. This has been left open and can someone advise if this is a breather or should it be blanked off.
Mon Jul 20, 2015 6:28 pm » Post: #2 » Download Post
It is a breather, it should have a bit of rubber breather hose attached.
triggerrogers
Mon Jul 20, 2015 6:33 pm » Post: #3 » Download Post
Thanks for the info. I will attach a breather hose to it.
Tue Jul 21, 2015 10:50 am » Post: #4 » Download Post
If you check the Online Parts Manual - MC18 section | E9 you will see the breather as part #3.
The tube runs under the carbs, and down the back of the motor, between the motor and swingarm, and then you will see a wire holder for it down below [and just in front of] one of the footrest brackets. I can't remember on the MC18 if it should exit on the left or right side though.
