I had given up but spoted a ns 125 piston on ebay will this fit its the same bore size 56 mm . i know from research the ns 400 pistons fit if cyclinders are bored out, but prefer not to do this.
as cyclinders ive been told look good ditto the crank . anyone know the guedion pin dia of the ns 125 . i read where the ns 400 are the same diameter.
the machine has no body work but i got it for 300.00 nz whould like to get it going one day it needs alot work and i never worked on a two stroke honda .
