I have completed about 50/80kms on my 21 after putting it back together and have 2 problems.Both of the port/chamber gaskets are leaking.I have TYGA pipes fitted and I made sure the surfaces were clean when I assembled them.Is this common or is there a trick to getting these to seal?Also the gear selector seal seems to be leaking.Are these easy to change?Your thoughts always appreciated.
