a few questions
peewit
a few questions
Thu Jul 21, 2011 1:13 pm » Post: #1 » Download Post
hi all, my nsr has no water in the radiator or bottle( hasnt been run like this). im just wondering on how to fill the rad back up? can i fill the rad to the top and then fill the bottle to its mark? also i need new front disks and new discs for the mc16 are pricey so would there be a cheaper option like vfr, cbr discs?
Thu Jul 21, 2011 3:05 pm » Post: #2 » Download Post
just fill them up as you have described mate
Neal
Thu Jul 21, 2011 3:53 pm » Post: #3 » Download Post
Lean your bike to the left at 45 degrees and this helps the air get out of the radiator so you can top it up
peewit
Thu Jul 21, 2011 5:39 pm » Post: #4 » Download Post
thanks guys, thought thats how you do it but safer to be sure.
thanks again Very Happy
Jim
Thu Jul 21, 2011 11:20 pm » Post: #5 » Download Post
fill it up, gently squeeze the hoses to purge some air bubbles, let it idle a few minutes with cap off, shut it off, and top off as needed. At least that's what i have done in the past.
-Jim
'93 MC21
anonymous.shyster
Thu Jul 21, 2011 11:49 pm » Post: #6 » Download Post
So you don't bleed them? On the KTMs we've got there is a bolt that you undo on both the head and radiator. You unscrew them to purge the air, screwing them back in when coolant comes out.
cgallant
2001 Honda RS250
Fri Jul 22, 2011 11:54 am » Post: #7 » Download Post
NSR's dont have bleeders on the cylinders like the Honda RS (or the KTM it sounds like).
Without the bleeders, I would fill up the radiator, squeeze the hoses, tilt the bike approx 45 degrees to each side, refill, repeat till the level in the radiator doesn't go down anymore.
I do this same process with my RS with the exception of bleeding water pump, cylinders and head using the bleeder/purge bolts.
cangus
Fri Jul 22, 2011 2:31 pm » Post: #8 » Download Post
MC21/28 cylinders do have bleeders. At least mine do.
MC21R9N track
MC18R2J track
CBR954
CR250
cgallant
2001 Honda RS250
Fri Jul 22, 2011 2:51 pm » Post: #9 » Download Post
you are correct... cylinders do have bleeders, heads dont.
Fri Jul 22, 2011 5:25 pm » Post: #10 » Download Post
Surely that renders them utterly useless? Gravity will do the front cylinder and head, it's the top head you're concerned about (if you're concerned at all, all I ever do is run it up with the rad cap off and fill it up.
cangus
Fri Jul 22, 2011 6:44 pm » Post: #11 » Download Post
it wasn't that long ago i was the one asking the stupid questions.
i couldn't pass up an opportunity to correct a master. trivial as it was. Smile
MC21R9N track
MC18R2J track
CBR954
CR250
anonymous.shyster
Fri Jul 22, 2011 11:11 pm » Post: #12 » Download Post
On the KTMs I have the bleeders are on the heads. Which makes the most sense as the air will naturally go to the highest point. Of course, the highest point on the NSR would likely be the cylinder.
Sat Jul 23, 2011 8:51 am » Post: #13 » Download Post
I also lift the front wheel up as high as me (and someone else) can. But the side to side and squeezing hoses works a treat.
Sat Jul 23, 2011 10:38 am » Post: #14 » Download Post
Lifting it and shaking it? whats that all about, you cant do that with your car, do as fontyy says, run it up, fill it while running it, no problems.
peewit
Sun Jul 24, 2011 11:09 am » Post: #15 » Download Post
thanx for the replies everyone. the job is done now Very Happy
