I have a MC28 subframe that I do not need and you can have it for free ...though I believe the postage costs would be a little bit on the high side and I'm pretty sure that the mc16 tail will no longer fit. Check that it bolts on your frame and if you don't have any other alternatives, let me know.
By the way, you might want to consider fixing your own. Mild steel is not that hard to work on...
im afraid to say that the mc18 sub frame wont fit the 16. i ended up making a custom subframe and backend for my 16 by using a vfr 400 (mc 21 i believe?) frame. bits for the 16 are hard to find now trust me.
Thanks for the offer of the mc28 subframe - but they are miles away from a mc16/18.
I had looked into modding a vfr400 one so its good to know they have been done before.
