Piston identification help ?
Alzazorq
Mon Aug 08, 2011 7:48 pm » Post: #1 » Download Post
Hi all,
Wondered if someone can tel me which pistons these are ?
54mm bore, same piston pin as nsr. Flat tops.
Maybe from NF5 or NX5 ?
Its got the following stamped inside : ART 8C27
Thanks
Mario
Mon Aug 08, 2011 8:20 pm » Post: #2 » Download Post
If it has a 15mm piston pin then it not an NF5. I'v not seen a crank case inducted RS motor with a piston ported type piston between 1987-1992.
mixalisen
Mon Aug 08, 2011 9:00 pm » Post: #3 » Download Post
Stephen is right... Either are not from an NX5 or NXA... Even the "A" kit pistons from HRC or JHA for these bikes are not ported...
Mon Aug 08, 2011 9:03 pm » Post: #4 » Download Post
ND5?
Alzazorq
Wed Aug 10, 2011 8:05 am » Post: #5 » Download Post
Thanks for the help guys, whats a ND5 ?
mixalisen
Wed Aug 10, 2011 8:36 am » Post: #6 » Download Post
Mario hi,
ND5 is the Honda RS250 but before NF5's... Although i checked my parts lists of the ND5 machines and i sew also that the pistons don't have any ports...
Cheers Mario
Michael
toneless
Wed Aug 10, 2011 11:43 am » Post: #7 » Download Post
I believe nd5 had a bore of 56mm.
Looks like an old KTM or Honda Cr125 piston to me.
2t-racelab.com
Alzazorq
Wed Aug 10, 2011 2:46 pm » Post: #8 » Download Post
Thanks again for all the help guys !
Michael - ND5 = before my time, LOL !!
Maybe pistons from CR125 that someone wanted to use in their NSR motor as I got these with a pair of bikes I bought.
mixalisen
Thu Aug 11, 2011 10:31 am » Post: #9 » Download Post
Damm, i wish i could say the same Mario...!!! Crying or Very sad
2T Institute
Thu Aug 11, 2011 10:13 pm » Post: #10 » Download Post
The port in the rear skirt identifies the piston as a CR125, the comp height will define the year
