Note Advantage
1)The triple clamp has been modify to install on Mc28/Mc21. Dont come with Top clamp nut. ( Use back mc28/mc21 clamp nut)
2)I modify the Wheel axe spacer to fit mc28/mc21 wheel on this Rvf fork.
Disadvantage
3)No brake caliper ( Rvf and mc28 using the same caliper 63mm bolt to bolt)
4)No brake disc ( You can buy from Tyga 296mm brake disc)
Those forks will be sevice before sent out. No dent no leaking of oil. direct fit into Mc28/Mc21. 100% straight.
Mod edit: HTML image code fixed. No links that we have to copy and paste in future please.
FY
