Started stripping down Noodle to check crank seals etc etc to find out why it was such a 'dog' to start. Well I think that I found out why..see below...
The little four way plastic joiner was broken. I have carefully super glued it then I've built uop a layer of Araldite around the break. Should (?) be okay. If not, are they available to buy?
Then I removed the carbs and look what I found......One of the crank halves (1/4's) has heavy rust pitting on it. Has anyone seen anything like this before?
Help please!
Mike _________________ I don't mind dying...I just don't want to be there when it happens!
Jesus Mike, cant believe what im seeing, ill look see if i have a spare plastic cross piece. _________________ Proud Father of , 05 ktm 400exc supermoto 2018 honda crf rx supermoto
David Silver has the plastic cross piece, special order £13.22, ill check in the morning if i have one. _________________ Proud Father of , 05 ktm 400exc supermoto 2018 honda crf rx supermoto
I've never seen rust quite like this before, it appears to be quite thick.
Plus points: More crankcase compression (on one cylinder)
Negative points: Out of balance crank...... Wel you got to laugh _________________ I don't mind dying...I just don't want to be there when it happens!
I have my own ideas about this and this is why I wondered if 'anyone' had come across anything like this before. The crank was 'supposedly' new in 2004, I've got the reciept for it BUT is it posible that the crank might have been a 're-build' as this rusting only appears on this one crank halve. If there had been moisture in the crankcase (?) then surely it would have effected both halves. The rusting is all around the periphery so, in my opinion, that cancels that theory out anyway.
The rest of the motor, so far, looks superb.
Of course. I don't think that it is caused by 'sitting around'. I feel sure that the company that originally put the 'New Crank' in it were not, maybe, totally conversant with the word NEW! The other half of the web on that cylinder is completely spotless...it even looks like different metal...but maybe I'm just being paranoid now!
Is it possible to just get one part of the crank replaced?
It might be that I'm able to clean it off when I get the crank out?
I think you have stumbled on the answer Mike, yes you can split the crank, and yes, that company probably did'nt know what the word new meant. Having said that, their should'nt be any problems, clean it up put some new seals in while you have it apart and it should be good to go. At least we know where not to go in the future. _________________ Proud Father of , 05 ktm 400exc supermoto 2018 honda crf rx supermoto
Got the crank out tonight to look at the rust situation.
It's not as bad as I thought, I have cleaned it up but it has left the crank a bit pitted. Do any of the 'guru's' out there think that it will be ok?
Just to chec k the crank, I put it between centres on the lathe and there was only a small amount of 'throw-out' Don't laugh, I can't really read the meter but I remember from when I used to do my kart (single cylinder) cranks what was the allowable amount of movement. It's well within that spec! Not bad for a twin I thought!
Before:
After:
Do you think that I should try to clean the crank web up more. I didn't want to start removing metal.
Also, the bearing on the clutch side is well, dry! It's in good nick but it doesn't look 'well oiled' if you see what I mean.
One thing that I didn't mention, and I don't think that you can see from my 'phone' pics, is that the crank is quite 'blued' around the big end pin on rusty web.
Hobbit210 wrote:One thing that I didn't mention, and I don't think that you can see from my 'phone' pics, is that the crank is quite 'blued' around the big end pin on rusty web.
Mike
My crank is out at the moment and it is also "blued" around the crank pin... There's no sign of any damage though, so I suspect its quite normal.....?
