The little four way plastic joiner was broken. I have carefully super glued it then I've built uop a layer of Araldite around the break. Should (?) be okay. If not, are they available to buy?
Then I removed the carbs and look what I found......One of the crank halves (1/4's) has heavy rust pitting on it. Has anyone seen anything like this before?
Help please!
Mike
