MC21 water pump seal set
nobby62
Sun Jan 22, 2012 4:52 pm » Post: #1 » Download Post
I decided to change all the bearings and seals in the crank cases whilst the crank is out for rebuild.....
Today I removed the water pump bearings and seals but I am now worried that I may have caused some damage or even scrapped the outer casing Crying or Very sad The problem is the water pump seal set (19217-KV3-831). Can anybody advise if the steel shell is part of this seal or is it supposed to be permanently fixed into the casing.... I reached the point of no return when drifting it out, so its out now but completely wrecked.
Thanks for any help.
Sun Jan 22, 2012 6:05 pm » Post: #2 » Download Post
The steel shell is part of the water seal so dont panic. It is a bit of a git to remove though.
nobby62
Sun Jan 22, 2012 6:18 pm » Post: #3 » Download Post
Thanks for that Paul..... I can relax a little now.
