I've read about the leak down test you can do to check the crank seal by pouring fuel/oil mix into the top of the engine and
see if it leaks out the bottom. So as I had the barrels and pistons out I thought I would do this. I poured some mixture in the
top engine opening (onto the crank) and left it for a bit.
So far it hasn't leaked. Now, how do I get the mixture out? Or I have I done it wrong?
Don't say turn it upside down.
Cheers...
Al.
Cheers....
Al
Bikes:
GPZ900
NC30
NSR250SE
RGV250 vj22
