Oil Pump Setting: Quantitative.
TuckerBag
Fri Mar 30, 2012 10:33 pm » Post: #1 » Download Post
This link on NSR-World (Workshop -> Technical -> Oil Pump) shows how to set the oil pump.
I think the picture is a bit misleading. There are 2 marks on the oil pump cable pulley, and I think that the pictures above (and below) are indicating the use of the wrong mark.
The picture below shows the full thottle setting with adjustment set up to what I will call "Position 1"
This next picture shows the full thottle setting with adjustment set up to what I will call "Position 2"
I believe that Position 2 is the correct setting and gives a Fuel:Oil ratio of approx 37:1
Can someone please confirm this? And please let me know if I am wrong.
Also, can anyone give an indication on where you might set the oil pump for say 35:1 or 40:1 or 45:1 etc.
I am just curious to get an idea of how much the pulley alignment affects the fuel/oil ratio.
Dana
Fri Mar 30, 2012 11:58 pm » Post: #2 » Download Post
I adjusted mine to the full throttle mark.
http://nsr250.net/forums/viewtopic.php?t=10925&highlight=
I've done a couple trackdays at large tracks with that setting and she hasn't blown up yet...that's a good thing, right?
Dana
Sat Mar 31, 2012 10:39 pm » Post: #3 » Download Post
I think you might be right there!
When I started racing, I simply set mine to be fully open when the throttle was - hoping that would be the best for the engine. Sadly it was unable to compensate for my cackhanded jetting on a couple of occasions...
nobby62
Re: Oil Pump Setting: Quantitative.
Thu Aug 23, 2012 10:14 pm » Post: #4 » Download Post
I'm sure you are right there Tuckerbag....at position 2 setting the oil pump lever just begins to open as the carb barrelstarts to rotate, has to be right!...... Great Photo's too.
Sat Aug 25, 2012 9:14 am » Post: #5 » Download Post
Well spotted, the pic is correct (and lifted from the Honda Workshop manual) but the text is wrong the throttle setting should say 50% not full throttle.
Three years too late though
the edit on my post is to correct the pic URL's, bikepics changed them all
Rolling Eyes
