  • NSR250 Forums Index ‹ NSR500 Discussion
NSR500V deck height
NSR500V deck height
Wed Sep 19, 2012 8:11 am » Post: #1 » Download Post
Steve jaaaaaaaaa
What's the deck height on the 500V?
Wed Sep 19, 2012 11:59 am » Post: #2 » Download Post
Zero Wink
Makes you wonder doesn't it!
I measured squish at 0.7mm on unleaded and between 0.55-0.6mm on leaded. Leaded head volume is around 22.6cc, unleaded 23.8cc.
Wed Sep 19, 2012 12:58 pm » Post: #3 » Download Post
All good info Steve.
What's the squish area ratio for the two different heads?
Wishing I'd taken you up on the offer of bringing a head with me now Mad Then again I ended up throwing half my stuff in the bin at Heathrow cos I was over weight as it was Rolling Eyes
Wed Sep 19, 2012 1:20 pm » Post: #4 » Download Post
I thought you had a head?
I could post you one.
Wed Sep 19, 2012 1:44 pm » Post: #5 » Download Post
No, like a dumbass I didn't take one.
You could post me one, or you could tell the Mrs that you're just popping over to see Granty and then hop on the plane. I'll meet you at Swensen for a triple choc Sundae.
Wed Sep 19, 2012 1:49 pm » Post: #6 » Download Post
I'll post one.
Sun Sep 30, 2012 3:35 pm » Post: #7 » Download Post
Measured all the heads Matt.
Squish area is 24.75% of the 68mm bore. This doesn't include any radius onto the squish on leaded and unleaded.
Mon Oct 01, 2012 2:41 am » Post: #8 » Download Post
Cheers Steve. Good info.
That set up looks nice. I won't show you mine Smile
Mon Oct 01, 2012 7:49 am » Post: #9 » Download Post
It's not bad. It clamps onto a fitting on the mill table.
Mon Oct 01, 2012 11:46 am » Post: #10 » Download Post
Not bad, for a hack!
Tue Oct 02, 2012 2:48 am » Post: #11 » Download Post
I found an old bit of broken perspex down the dump. Drilled a hole in it.....works every time.
