SP or Not!
Hobbit210
SP or Not!
Wed Oct 31, 2012 8:45 am » Post: #1 » Download Post
What are the differences, if any, between an SP motor (MC21) and an SE or R.
If there are differences are there any disgusting marks/numbers on the outside of the motor to check?
Mike
Wed Oct 31, 2012 9:09 am » Post: #2 » Download Post
The SE and SP are the same.
The R has different heads and barrels, and of course a different transmission.
So long as you use R heads and barrels together on an SE/SP bottom-end, there is no performance difference. Do not mix SE/SP and R heads and barrels though. It is OK [although less than ideal] however, to run SE/SP on one side, and R on the other. Just don't mix the heads up.
Hobbit210
Wed Oct 31, 2012 10:23 am » Post: #3 » Download Post
Thanks Andy.
The reason for my query is that some time ago I purchased an 'SP??' motor. Noodle is an R and I wondered if I should put the SE/SP engine in.
Are there many external differences between the R and the SE/SE motors?
Mike
Hobbit210
Thu Nov 01, 2012 7:41 am » Post: #4 » Download Post
..anybody?
nxrsr20
Thu Nov 01, 2012 8:41 am » Post: #5 » Download Post
External differences are cylinder and head markings, plus the obvious dry clutch. You won't differentiate between an SE and SP motor though.
Hobbit210
Thu Nov 01, 2012 12:29 pm » Post: #6 » Download Post
Hi, thanks for that but 'what' are the different markings so that I can check both engines.
Mike
nxrsr20
Thu Nov 01, 2012 5:46 pm » Post: #7 » Download Post
Since I am not a walking NSR encyclopaedia like Andy, click on the links in the left, one of them will talk about model differences.
Thu Nov 01, 2012 6:44 pm » Post: #8 » Download Post
Wet clutch models have "H" cast into the heads and barrels. Dry clutch models have an "L".
Hobbit210
Fri Nov 02, 2012 8:03 am » Post: #9 » Download Post
Ahhh Thanks. Wasn't too difficult now was it!
Mike
Fri Nov 02, 2012 1:34 pm » Post: #10 » Download Post
http://www.nsr250.net/forums/viewtopic.php?t=3077
http://www.nsr250.net/forums/viewtopic.php?t=9090
http://www.nsr250.net/forums/viewtopic.php?t=2544
No, not hard at all! Confused
Hobbit210
Sun Nov 04, 2012 11:26 am » Post: #11 » Download Post
Oh dear.
Consider me Fully chastised!
I'll get me coat, and float level adjustment tool, and be on my way!!!
Tue Nov 06, 2012 6:59 pm » Post: #12 » Download Post
Basically if you can live with the lack of rattle (from the clutch) and the engines are in good condition you won't be able to tell a difference at all.
Anyway I think I'd strip the other motor and swap the gearbox/clutch (not a big job) and keep the spare barrels head and crank for a rainy day before I swapped a whole motor I'd never started for another I knew worked fine.
The R barrels are shorter, the R heads have a similarly larger volume, effectively when the motor is built the head gasket on the R motor it located 0.2mm lower.
In theory the dry clutch should give more power, but it's not a measurable amount.
Hobbit210
Wed Nov 07, 2012 11:03 pm » Post: #13 » Download Post
Thanks Fonty but here is the dilemma...I had already put a dry clutch in 'Noodle' during my rebuild. The motor that I purchased some months ago has a dry clutch and has 'L' on the barrel castings. SE/SP as purchased (hopefuly).
Noodle ALSO has 'L' stamped barrels but had a wet clutch. Eekk!!
I'm not really worried either way but it's a bit weird. One thing that I am worried about though...whoops, that's for another post I think as I'm about to go off topic slightly and I'm already in Andy's bad books already. (Place relelvant emoticon here!!)
Mike
Wed Nov 07, 2012 11:25 pm » Post: #14 » Download Post
Why? All it means is that at sometime the motor has been apart and the barrels changed.
Hobbit210
Thu Nov 08, 2012 10:44 am » Post: #15 » Download Post
..thought that must be the case!
