fork seal drama
paul
fork seal drama
Sat Feb 23, 2013 7:56 am » Post: #1 » Download Post
the drama of fixing other peoples ruff jobs on my race mc21 goes on
at the last meet the fork seal started leaking real bad, to get me through the day I went to put a rag under the dust cap only to find an oil soaked one already there
now with the forks apart it appears the seal has been glued in!!
they are all apart but the seal just wont move
any ideas?
Alzazorq
Sat Feb 23, 2013 8:11 am » Post: #2 » Download Post
Clamp outer in vice using the caliper mounting points, then heat outer with a blue/butane flame where seal sits. Then yank on inner until the seal starts to move.
paul
Sat Feb 23, 2013 9:31 am » Post: #3 » Download Post
Thanks man, that worked sort of, it loosed the seal enough so that i could gently get it out with a small screwdriver, however the washer bewteen the seal and the bush seems to be the real issue, thats jammed in there I
Alzazorq
Sat Feb 23, 2013 10:12 am » Post: #4 » Download Post
That's why I said to use the inner to yank all of the parts out...This way you won't damage anything! Stay far away from screwdrivers when working with forks ! Glad it helped !
Neal
Sat Feb 23, 2013 1:05 pm » Post: #5 » Download Post
check that there are no stone chips on the chrome as it will rip your new seal
paul
Sat Feb 23, 2013 9:06 pm » Post: #6 » Download Post
there are some chips, would say why that was blown in the first place
bit of a delima now, put it back together, smooth off the chips and hope for the best
go a bit further and attempt to get the washer out
or another fork leg, does anyone know if mc16 forks will work with 21 internals?
