Mc28 sp rear shock
mighty max
Mc28 sp rear shock
Tue Apr 02, 2013 8:41 am » Post: #1 » Download Post
Hi, can the rear stock mc28 sp can increase the height..
Tue Apr 02, 2013 1:22 pm » Post: #2 » Download Post
No. You would need an HRC or aftermarket shock such as Öhlins, WP, or Nitron.
You could try having a new linkage "rocker" machined, but it's not a simple job like with the earlier models [that just use triangular plates], as for a start it would need to be CNC'd. Getting the new geometry even minutely incorrect would seriously effect the handling, and be expensive to develop because of the machining costs. There is also only a very small margin you can work with when modifying the linkage geometry, as it also progressively effects the "rising rate". (Google it!)
mighty max
Wed Apr 03, 2013 1:38 am » Post: #3 » Download Post
Thanks..
