21 engine in a 28 frame, which chambers do I need?
diviCe
Tue Jun 25, 2013 1:14 am » Post: #1 » Download Post
Hi guys,
I know there's a difference between the 2 chambers... are the chambers made to fit the engine or the frame?
My 28 frame has a 21 engine, so which one would I need?
Thanks
Minh
It's Good to be Bad!
nxrsr20
Tue Jun 25, 2013 7:15 am » Post: #2 » Download Post
It's made to fit the frame.
I would be more concerned about running the PGM4 with the lighter flywheel. Check on it regularly and adjust settings to suit.
diviCe
Thu Jun 27, 2013 4:51 pm » Post: #3 » Download Post
It's not safe to run standard card on the 21 flywheel?
nxrsr20
Fri Jun 28, 2013 8:20 am » Post: #4 » Download Post
Sticking to the normal mantra..... You are deviating from a stock configuration which means it hasn't been set up for that.
I haven't had a 21 and 28 flywheel side by side so I don't know if the pickups are in the same location.
The fact that no one else is commenting means that it may not have been documented before.
