does mc21/28 crank suit mc18r5k ?
andyburton1977
Wed Jan 08, 2014 12:52 am » Post: #1 » Download Post
hi folks
this is probably common knowledge but can anyone confirm if the mc 21 or 28 crank shaft is suitable for use in an mc18r5k motor ?
cheers
andy
Neal
Wed Jan 08, 2014 8:04 am » Post: #2 » Download Post
You have to split the crank , turn down the webs and re assemble .
What's wrong with your original crank ?
geezagillard
Wed Jan 08, 2014 6:18 pm » Post: #3 » Download Post
From memory the webs need 2mm taken off (total of 4 off the diameter), otherwise should be fine. There has been significant discussion around this issue but all looks to have been deleted.
TuckerBag
Thu Jan 09, 2014 7:36 am » Post: #4 » Download Post
The MC18 R5/6k has a crank wheel (or web) diameter of 96mm
The MC21 and MC28 has 100mm diameter crank wheel.
All have the same stroke of 54.5mm
