Brake line connections
kneewall49
Sun Jan 26, 2014 8:10 am » Post: #1 » Download Post
Just getting back to my nsr after finishing a tzr, and have realised the ss brake lines I have have a different fitting to those I'm familiar with, ie no banjo bolts on the callipers?
Can you tell me what I need, the name of the part, to attach these lines to the the callipers?
80XAR
Mon Jan 27, 2014 10:36 am » Post: #2 » Download Post
Hey. Mate. Just take the line and caliber to a shop that sells speedflow and get the right fitting for the caliber to suit those lines. That fittings on the hose seals on a tapered seat opposed to an copper oring and banjo. What you will need is a '200 series' stainless fitting. Not sure on size, but they can check that at the shop. If you were in qld I could direct you to a shop, not sure of anyone in Sydney. Just google speedflow and find a distributor down there. Should be a 200 series fitting, but they'll check it out for you.
kneewall49
Mon Jan 27, 2014 7:02 pm » Post: #3 » Download Post
Ok found a place at Seven Hills, just along the M4 from where I work. Thanks for the advice. Smile
kneewall49
Wed Jan 29, 2014 9:00 am » Post: #4 » Download Post
Boxar,
Picked up the bits today. Great place for lots of tricky bits, and nice guys too, ie Motorsport Connections, Seven Hills.
Thanks for your advice!
