Was hoping someone may be able to help. In the engine rebuild section it mentions lining up the dots on the primary drive gear and the crank. I just stripped my engine and I can't see a dot on either the end of the crank or the gear. I want to install my new crank. Is this alignment essential? It doesn't mention anything about it in the service manual from what I can see.
Jim
