Removing pv cables
Manny514
Removing pv cables
Sat May 23, 2015 4:49 pm » Post: #1 » Download Post
I am currently stripping an r6k, what's the correct way to remove the power valve cables?
Sun May 24, 2015 7:20 pm » Post: #2 » Download Post
Best way is to remove the nut **CAUTION -- LHT** holding the pulley on to the RC Valve shaft, and then simply flip the pully around (as if you were turning something inside-out).
Make sure you pay special attention to the order of the washers behind the nut. The washers/nut are (a) special, and (b) no longer available, so make sure you wire/cable-tie the bits together, and put them somewhere safe! Wink
** AGAIN ** The nut holding the pulley on is left-hand-thread. Exclamation
Manny514
Sun May 24, 2015 7:40 pm » Post: #3 » Download Post
Thanks sir you're a scholar, just didn't want to do any damage by getting in a rush
