I'm stripping my forks and have a couple of questions...….
What is the free spring length for a 1988 MC18? Mine both measure 270mm but the only info for NSR springs I can find is a service limit of 287.5mm ( not sure which model that applies to).
The body of the oil valve located at the bottom of the fork, should this knock/push out towards the top of the fork? I want to get the forks rechromed so this needs to come out?
As you can probably tell, I've not had to take forks this far apart before.
Rich
