Thanks for your reply, the NXA is one I've bought for another rider who rides both road and enduro bike as well race bike , so he prefers the road shift pattern.
I've inverted the lever on the gear shift shaft , not ideal as the angle is not correct, but I think it will work ok.
The NX5 uses an alternate linkage. Well, less linkage really.
From the parts book, it looks like it's just a male & female M6 rose joint, rather than two male (one LH one RH) and a threaded adjuster rod.
NX5 road shift part numbers are:
24711 NX5 004 - Rod end 6mm, A (Male)
43506 NC8 000 - Rod end 6mm (Female)
I would imagine that the position of the gear pedal and selector shaft is the same or similar on both NX5 & NXA, so it should be possible to buy a couple of M6 rose joints. Getting the correct length would be the hard part. _________________ If it ain't broke, fix it until it is.
MarkR wrote:The NX5 uses an alternate linkage. Well, less linkage really.
Buy normal way threads rose joints the use threaded rod to get the corect lengths
I've just noticed that there are two gear pedals for the NX5, so it may not be possible to just change the linkage.
24700 NX5 800 - Road shift pedal _________________ If it ain't broke, fix it until it is.
