I have scoured Google to no avail! My fuel tap (standard Honda part, I believe) has a little arrow on one side of the plastic tap. If I turn it fully clockwise then the arrow is pointing upward - if I turn it the opposite way then the arrow ends up at the bottom. If horizontal is off, which way is reserve?
Hi Ian, looking at the tap, mine is, horizontal = off, clockwise = reserve, anti clockwise = on, my tap doesn't have an arrow on it, it has on- off and res, which lines up with a little arrow on the bottom edge of the fuel tank, if your tank has been re painted you probably haven't got the little arrow and fuel decal. _________________ Proud Father of , 05 ktm 400exc supermoto 2018 honda crf rx supermoto
Ok thanks a lot Les - it was on reserve then, so I'll set it to 'on'. I ran out of fuel on Saturday!! I might also zip-tie a 100ml bottle of oil somewhere for emergencies, given it's premix.
Thats exactly what i used to do to mine when i rode it on the road, i velcro'd it up in the nose cone. _________________ Proud Father of , 05 ktm 400exc supermoto 2018 honda crf rx supermoto
