Mc16 servo problem
Philip laws
Mc16 servo problem
Sun Mar 05, 2017 6:48 pm » Post: #1 » Download Post
Power valve servo on my mc16 only starts to work if I flick the kill switch off and on while the engine is running. Any ideas on the cause of this problem would be gratefully received. Thanks in anticipation
KL2585
Mon Mar 20, 2017 8:11 am » Post: #2 » Download Post
Oh, I have same problem. My is MC21. I disconnect the wire on pulley. When i turn the key to "on", and press the kill switch to "run", the servo just shake a bit and the servo go to "HI" position.
I tried to turn off the key, moved the pulley to "LO" position by hand and turn the key to "on", the pulley moved to "HI" again.
I checked the motor and variable resistor on the servo and both are in order. I also checked the TPS and battery voltage and seem no problem.
So, I want to ask:
1) if the servo have movement, can i said the PGM unit is OK?
2) Any work shop manual for MC21?
3) If PGM is ok, the harness......
Cheer
