  • NSR250 Forums Index ‹ RS250R Discussion
Exhaust heat shield
TomB
Exhaust heat shield
Sun Apr 23, 2017 12:07 pm » Post: #1 » Download Post
What do you guys use for protecting the paint on the bellypan from the heat of the exhaust? I recently used exhaust wrap for cars, but it's not resistant enough to the heat, and the paint started to blister.
Sun Apr 23, 2017 8:33 pm » Post: #2 » Download Post
Look on the good old flea bay, i'm sure you can get the proper stuff on there.
MarkR
Sun Apr 23, 2017 8:42 pm » Post: #3 » Download Post
I use the genuine heat proof sticky pads
64109-NF5-750
Not cheap, but they stick like $h17 to a blanket, don't come unstuck when you wash the belly pan and wear well. I've had them last for a season or more. You'll probably need a couple on the Left, depending on your pipes.
If it ain't broke, fix it until it is.
Mon Apr 24, 2017 1:12 pm » Post: #4 » Download Post
I used a product from Zircotech with a ceramic layer, which is very thin
TomB
Mon Apr 24, 2017 7:48 pm » Post: #5 » Download Post
Is that the zircoflex 1, 2 or 3? I like that it is so thin.
Mon Apr 24, 2017 8:15 pm » Post: #6 » Download Post
I went for the thinnest. There are some pictures on my nsr rebuild
tdijam
Thu Apr 27, 2017 7:38 am » Post: #7 » Download Post
I also use the OEM Honda heat shields , I've tried other products but not found anything better .
MarkR
Thu Apr 27, 2017 8:03 am » Post: #8 » Download Post
RobH wrote:I used a product from Zircotech with a ceramic layer, which is very thin
Never seen that before. Looks very good. Also makes the OEM pads look cheap.. Wink
Thu Apr 27, 2017 9:24 pm » Post: #9 » Download Post
