Rebuild/gasket question
Dexter
Mon Jun 13, 2005 6:50 pm » Post: #1 » Download Post
..couldnt find it with a search...
So when you do a complete teardown on an 21 engine what are the things you need to buy new , for the rebuild?My first guess is some gaskets.I m planning to do one very soon so I want to get me whatever is needed.Where can I find out more about this , I need part numbers for every single thing Evil or Very Mad
..another thing , does anyone have the part number for the HRC0.6mm lower cyl gasket ?Thanks...
Mon Jun 13, 2005 7:00 pm » Post: #2 » Download Post
If you read the full engine rebuild section in the Workshop, this will give you pretty much all the info you need.
Check the Online Parts Manual for schematics of the engine/complete bike.
These two resources alone should be enough to ascertain what you will require for your particular rebuild.
The HRC 0.6mm gaskets are available in the Marketplace.
We can supply OEM parts if you are struggling to get them from your local dealer. Where are you located?
Dexter
Mon Jun 13, 2005 8:20 pm » Post: #3 » Download Post
Greece.Unfortunately our Honda dealer seems to ignore the particular Honda product (meaning the godamn NSR)
