  • NSR250 Forums Index ‹ RS250R Discussion
Nx5 clutch
TomB
Nx5 clutch
Fri May 20, 2022 8:28 pm » Post: #1 » Download Post
Any chance the nsr250 mc28 has the same clutch as the nx5? If anyone has the mc28 dimensions, I'd really appreciate it.
Sun May 22, 2022 12:38 am » Post: #2 » Download Post
Totally different, I'm afraid.
Racer38 could probably help you out with some dimensions, if he's feeling charitable. He has an MC28SP and an NXA in his shed, and knows which way round to hold vernier calipers. I'll ask him.
Mon May 23, 2022 6:16 am » Post: #3 » Download Post
What dimensions did you need and what are you trying to do?
TomB
Wed May 25, 2022 9:16 pm » Post: #4 » Download Post
I have an nx5, but Honda have stopped making the clutch frictions. I was hoping to find another model which used the same frictions, thought that maybe the nsr might be the same.
I've tried Barnett, and they're fine for practice. But they fall apart after one race start.
Any suggestions/advice welcome.
Thu May 26, 2022 2:59 pm » Post: #5 » Download Post
These T2 Racing plates are for NF5. No idea if they are compatible for an NXA
https://japan.webike.net/products/24104118.html
Thu May 26, 2022 4:06 pm » Post: #6 » Download Post
NF5 is the same (ish!) as NSR250R.
T2Racing do run a couple of NXAs, so can probably help. I'll ask.
Thu May 26, 2022 4:45 pm » Post: #7 » Download Post
Nf5 frictions are different to NX5, i have had my NF5 ones relined by a company called Saftec in West Yorks, tel; 01274 862666, quick turnaround, and they have been no problem.
TomB
Thu May 26, 2022 8:02 pm » Post: #8 » Download Post
Thanks guys, 2 good possibilities there. Will call Saftec tomorrow. Andy, would appreciate if you could ask T2 Racing, thanks.
Fri May 27, 2022 2:40 am » Post: #9 » Download Post
Do you know the specific part numbers you require, Tom? Is it as follows?
22201-NX5-003 x4
22202-NX5-000 x2
TomB
Fri May 27, 2022 5:02 am » Post: #10 » Download Post
Yes Andy, these are the correct part numbers.
Fri May 27, 2022 1:29 pm » Post: #11 » Download Post
T2R say they should be able to supply a new set of fibres, but Matsumoto-san says he had a very good used OEM Honda set personally, if it's of any use? Are you racing or parading?
He'll check with his supplier for a price & availability.
TomB
Fri May 27, 2022 6:40 pm » Post: #12 » Download Post
Hi Andy. I'm interested in both, please.
And it's for racing, not parading.
Thanks for your efforts, much appreciated.
Sat May 28, 2022 12:04 am » Post: #13 » Download Post
The 6 new OEM fibre plates will be ¥30,000 (about £187 current exchange rate) + shipping.
He says he also wants ¥30k for the used plates, but there are about 20 of them.
TomB
Sat May 28, 2022 7:09 am » Post: #14 » Download Post
I'll have the Frictions Andy, but not the steels, I have plenty of spare steels.
Sat May 28, 2022 1:07 pm » Post: #15 » Download Post
Pretty sure he means the 20 used plates are friction plates too, but I'll check.
Edit: He says the used ones are friction plates, and good to use for practice and testing to save wear on the new plates for the race(s).
