MC16 water pump seals
eben
Thu Dec 11, 2025 1:12 pm » Post: #1 » Download Post
I am restoring a NSR MC 16
Can anyone tell me which way the black waterpump seal go in Does the flat side of the seal face the waterpump bearing or the other way Also where does the black and white seal go ?
Thu Dec 11, 2025 5:19 pm » Post: #2 » Download Post
Hello "eben", and welcome to NSR-WORLD.COM!
Here is the technical diagram for the water pump assembly from the MC28 service manual, which is generally much clearer than the photos they used in the MC16-21 service manual. The setup for all models is the same.
http://nsr250.net/forums/members/nsr250r_manual_mc28/index.php#p=90
The open end of the inner seal [part #] faces the bearing.
*NOTE: You must be logged in to the forums to access the Service Manuals.
eben
mc16 water pump seals
Fri Dec 12, 2025 7:59 am » Post: #3 » Download Post
Thank you Andy
Still not clear on the black and white seal
Is it part of the water seal?
Mon Dec 15, 2025 4:43 pm » Post: #4 » Download Post
Sorry, completely overlooked that part!
White side goes towards the impeller. (Faces outside.)
