HELP MY NSR STOPPED WORKING!!
JONNY1DECK
Sun Aug 14, 2005 5:58 pm » Post: #1 » Download Post
Hi there, I have just got my new nsr250 Mc18 RK5 up and running after buying it a few weeks ago. Took it to the get the MOT, it passed!! I was very happy, so went up the road for about a mile, the indcators started to fade. Then i stopped at a roundabout it cut out, I turned the headlight off it started, went and got some petrol as I thought that maybe the problem, went well for about 5min then started to miss, then power just went and the bike stopped. No very happy as I had to push it for about 2 miles!!! I checked it today and it started for about 2 seconds and went dead.
Any ideas, by the way the battery was new, also the spark plugs. Crying or Very sad
Barry_MC21
Sun Aug 14, 2005 6:30 pm » Post: #2 » Download Post
'ello mate, great name! Wink
Sun Aug 14, 2005 6:32 pm » Post: #3 » Download Post
Is there two stroke oil in it?
Wrench.
Sun Aug 14, 2005 6:49 pm » Post: #4 » Download Post
Voltage regulator problem? Battery died and the bike wont run? Hopefully it is just something that simple.
Paul Herr
'88 FZR4/GSXR/YZF Frankenbike
MY BIKE PICS
Jeff SZ
Sun Aug 14, 2005 7:05 pm » Post: #5 » Download Post
Wrench hit it right, my bike did the same thing with new battery it would go for a while and things would fade, then the tac would go coo-coo and start misfiring and die. I would wait several minutes and it would run a little longer. So installed new after market reg/rec and it would be fine for days, then it would happen again and repeat. Turned outI had a bad harness, replaced that and never came back.
JONNY1DECK
Hopy this will work.
Sun Aug 14, 2005 10:59 pm » Post: #6 » Download Post
Cheers guys, I'll try and get hold of a Voltage regulator, that is the thingy on the side with the fins?? Any body know a good place to get them? Also can you use other honda types?
Jeff SZ
Sun Aug 14, 2005 11:08 pm » Post: #7 » Download Post
not sure for a MC18, but for a MC21 this works !
http://cgi.ebay.com/Honda-Regulator-CBR-600-900-F2-F3-NEW_W0QQitemZ7992153879QQcategoryZ10460QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
JONNY1DECK
CHARGED THE BATTERY UP AND IT STARTED!
Mon Aug 15, 2005 11:39 am » Post: #8 » Download Post
I have just charged the battery up it starts, how can I check the coil and the rec/reg are doing their jobs? If the rec/reg had gone would that stop it changing??? I felt the rec/reg it was warm? Confused
Mon Aug 15, 2005 11:43 am » Post: #9 » Download Post
They do get hot, hece the need for a big heat sink and fins.
To check the charging circuit, check the voltage on the battery with the engine running above 2000rpm. It should be about 13.5-14.5 volts.
Jeff SZ
U need a volt meter
Mon Aug 15, 2005 1:32 pm » Post: #10 » Download Post
http://electrexusa.com/electrosport_fault_finding.html
JONNY1DECK
Gone Flat again.
Tue Aug 16, 2005 8:08 am » Post: #11 » Download Post
I Checked the votage on the battery, it was reading about 11.5 to 12, when I reved it to 2,000 it went down to 10, Seams to not getting any charge. Anyway went out for a quick ride, it seamed ok for about five mins, all dash lights bright. Then it got dark so I had to put my lights on, it started to play up, got home this time, in steath mode no lights!!! So it sounds like a Reg? I'll also have a look at the fault finding chart. Anybody know where to get a reg in the UK, and can I use one from a other Honda bike?
Cheers Guys
Tue Aug 16, 2005 8:40 am » Post: #12 » Download Post
Just about any will do, but the genuine Honda ones don't seem very robust. You might be better with an aftermarket one.
Barry_MC21
Tue Aug 16, 2005 8:49 am » Post: #13 » Download Post
Jon,
Have a look on ebay, but for CBR & VFR 400 parts, there are loads on there and a regualor off there should be fine.
