dented exhuast pipe
biatchy
dented exhuast pipe
Thu Sep 29, 2005 3:00 pm » Post: #1 » Download Post
hi all...
my problems just never seem to end. Mad
one of my exhaust pipes has two dents in it....i think it happened when the previous owner crashed it...
how would i go about takin them out?
cheers
Philip Ahn
MC21 NSR250R
im poor...
bryan_au
Thu Sep 29, 2005 10:33 pm » Post: #2 » Download Post
Are they the stock chambers Biatchy? If they are I wouldnt be particularly worried about it as you'll be wanting to swap them over for a set of race chambers after you've come for a ride with the rest of us Melbourne guys Wink
Thu Sep 29, 2005 10:56 pm » Post: #3 » Download Post
bryan_au wrote:Are they the stock chambers Biatchy? If they are I wouldnt be particularly worried about it as you'll be wanting to swap them over for a set of race chambers after you've come for a ride with the rest of us Melbourne guys Wink
LOL, but on a serious note there's nothing wrong with the stock '21 chambers, Bill's seen 66bhp out of his Surprised
No dents in his though.
biatchy
Fri Sep 30, 2005 12:30 am » Post: #4 » Download Post
yeah they are the stock ones...
they are quite small dents...maybe 10mm diameter circles...5mm deep..
i just that maybe cos the shape of chamber is so important it could have an effect on the engine...
dont want another seizure or nuthin... Crying or Very sad
i heard you can weld a rod or sumthin like that to the dent and then using a machine or sumthin to pull it out?
Smile
Philip Ahn
MC21 NSR250R
im poor...
fstnsr
Fri Sep 30, 2005 1:00 am » Post: #5 » Download Post
what u can do is plug up one end then pressurize the other and heat the dents with a tourch. they should pop out once hot enough
94 mc28 SE
biatchy
Fri Sep 30, 2005 1:40 am » Post: #6 » Download Post
cool....
thanks fstnsr...
what could i use to pressurise it?
Philip Ahn
MC21 NSR250R
im poor...
fstnsr
Fri Sep 30, 2005 2:34 am » Post: #7 » Download Post
compressed air or even if u block both ends as it heats the air shold expand and create a preasure.
94 mc28 SE
Luke F
Fri Sep 30, 2005 9:05 am » Post: #8 » Download Post
If there stock dont worry
They have a second skin for noise regs so it will not affect performance, I know cause I cut my stock pair apart years ago, and also its real thick stuff so not like you could pop down your local moto x shop and get them to tap it out its what most do all day long.
Farting is funny
Fri Sep 30, 2005 1:43 pm » Post: #9 » Download Post
fstnsr wrote:what u can do is plug up one end then pressurize the other and heat the dents with a tourch...
biatchy wrote:what could i use to pressurise it?
fstnsr wrote:compressed air or even if u block both ends as it heats the air shold expand and create a preasure.
Using compresed air is extremely dangerous, as the pipe can explode. Any pipe builder worth his salt would most likely use hydraulic pressure - probably oil - but it's not a job to be undertaken lightly.
Send a PM to "martin77" and ask him - he'll be building our race pipes soon.
Like a few of the guys have said though, if they are stock pipes then I wouldn't worry too much as it's probably only the outer "skin" that's dented anyway.
biatchy
Sat Oct 01, 2005 12:57 pm » Post: #10 » Download Post
cool...thanks guys..
yeah i was just worried it woul effect the performance drastically...
guess not Smile
cheers
Philip Ahn
MC21 NSR250R
im poor...
