Tyga arnt that bad, if its in stock it should be with you in 7 - 10 days MAX, my stuff was here within 6 days of posting, 2 days spent in LONDON as they dont work weekends. (or so they say)
also use this site to ask ANDY! he may have some!
Ask Andy. I got my stuff through extra fast cuz of the dyno day (not that it all came off...) so they will ship fast if needs be. I think you'll find the prices pretty damn competitive, and you'll be supporting this site too! _________________ MC21SP Plaything
Concerning pistons, you'll have to find your cylinder size before you go ordering. There will be a stamp (A, B or C) on the back lower edge of the cylinder. This is the size. You will then need a piston matched to this.
However, this is not always true, and really applies to new or nearly new cylinder as if your cylinder is worn then there's a good chance than on 'oversize' piston will be in order.
Skooter wrote:The cylinder is being welded, re-machined & Nicosil replated, so i guess standard size will be required.
Who's doing the repair work for the cylinder? _________________ MC21SP Plaything
Apparently there's a couple of places fairly localish that most people/dealers around here use. He did try contacting Stan Stephens a number of times, but without joy.
Who do people on here usually use? _________________
I've used Langcourt's a couple of times. Others go through Apex leisure, who use a third party. Be interesting to know... _________________ MC21SP Plaything
There's another wilts resident on the board too. Maybe we should have a mini meet? _________________ MC21SP Plaything
Dave Ett wrote:Could be worse, could be from Calne!
Dave Ett wrote:There's another wilts resident on the board too. Maybe we should have a mini meet?
Sounds good
My 18 won't be on the road for at least another few weeks, but always nice to know a few local people that share the interests & maybe a bit of knowledge _________________
Mine will be off the road until Spring I think! It's in lots of bits and I'm too damn busy to rebuild it now that winter is here...
We could always sit and look at it I guess... _________________ MC21SP Plaything
I use someone called DPS in keighley. They do alot of MX stuff and were quite happy to do the NSR's. _________________ If I have to take the carbs off once more...
