PJ38 Carbs
PJ38 Carbs
Fri Mar 31, 2006 12:05 pm » Post: #1 » Download Post
Wanted to get hold of a set of PJ38 carbs but know they are as rare as rocking horse teeth. So my question to the brotherhood is what else uses these carbs. I'm thinking CR250/500......would this be correct?
maxim
Fri Mar 31, 2006 1:00 pm » Post: #2 » Download Post
Tom, Tom, Tom... Wink Yes I think there are a number of bikes that use these. Or you could try Stephens 39's... They are probably easier to get hold of!
jkolewski
Fri Mar 31, 2006 2:28 pm » Post: #3 » Download Post
The carbs are the easy part! Finding the boots to mount them is where the fun starts. Any PJ motorcross carbs will work with the right jetting or you can go straight to Kehin. From what I'm told the boots are as rare as gold. Good luck!!! Laughing I found mine on E bay.
1995 A kit TZ 250
1994 Rothmans NSR 300sp SOLD
Matt@TYGA
Supporter - Vendor
Supporter - Vendor
Sat Apr 01, 2006 3:28 am » Post: #4 » Download Post
Paul was whining 'cos I haven't got a set of insulators for him, so I'm in the process of modifying my 300 cases to take the later (bigger) NF5 reed valves and insulators, and will donate my insulators to Paul.
I'm a bit fed up with all the talk about torque in the midrange, so I've got a plan to take a big spoon, scoop out everything below about 7 grand and dump it on the top. Totally unrideable but should be good for a laugh.
Sat Apr 01, 2006 3:46 am » Post: #5 » Download Post
I've a set of the carb boots so no problem there, just wanted to know what might fit. Been offered a set of carbs without p0wer jets.......that mean they won't idle?
Matt are you trying to say that now you've mastered the 300 on dusty, pot hole ridden roads you wanna make it a little more 'interesting'. You thought about setting the power valves to fully open all the time. Nothing .....nothing......then bam we hit the powerband. Just like my old TZR125, arhhhh....memories
Kieran
Tue Apr 04, 2006 8:08 am » Post: #6 » Download Post
I've put RS250 PJ 38 carbs on my 'priller 250.
MAN. Does it GO!!!
Better all through the range, and up top. Shocked
Go for it...
The Chopster
Matt@TYGA
Supporter - Vendor
Supporter - Vendor
Thu Apr 06, 2006 7:54 am » Post: #7 » Download Post
Man there's a lot of material to cut out if you want the later NF5 reeds valves........boring........whizz whizz whizz
Kieran
Mon Apr 10, 2006 10:41 am » Post: #8 » Download Post
Laughing
The Chopster
