Rear head on front cylinder
Steve C
Mon May 08, 2006 3:33 am » Post: #1 » Download Post
Well my mc21 is up and running Very Happy ( After a year Sad ). I did the rear head conversion while it was apart. I found out today that the front sparkplug wire is too short to reach the sparkplug from the stock mount. I was thinking of making a longer mount for the coil to mount on.
What other options do I have to fix this problem ?
Mon May 08, 2006 3:37 am » Post: #2 » Download Post
If you use th eshort plug and cap, the lead is just long enough! Wink
When I first did mine, before using the HRC parts, I simply cable-tied (tie wrapped) the coil to the clutch cable.
Steve C
Mon May 08, 2006 4:18 am » Post: #3 » Download Post
Hey Andy is there a shorter plug than the BR9ECM ? Is it the plugs they use in the RS250?
The spark plug sure looks close the front tire Laughing
Mon May 08, 2006 4:26 am » Post: #4 » Download Post
Have a look here!
Wink
