Fork springs
sparky
Fork springs
Thu May 25, 2006 9:54 am » Post: #1 » Download Post
which HRC fork springs would be recommended for use with an ohlins rear?
HRC fork springs for the MC21 are part #
51402-NH3-761 rated at 0.6-0.85 kgf/mm
51403-NH3-761 rated at 0.7-0.9 kgf/mm
I weigh 170 pounds.
sparky
Thu May 25, 2006 4:20 pm » Post: #2 » Download Post
I've been told HRC springs are discontinued.
anyone have the race tech part number?
Samk
Springs for front end
Thu May 25, 2006 6:17 pm » Post: #3 » Download Post
You might want to use the stock spring with thicker oil.
Just a suggestion, I was going to change mine to race tech but the one they have is quite stiff(at least for street use).
Good luck
SamK
90 NSR SP
Thu May 25, 2006 6:21 pm » Post: #4 » Download Post
Surely you want to use a rear shock spring on a rear shock? Front springs look far too long to fit on there! Wink
JohnBlaze
    Send private message View user's profile Visit poster's website AIM Address
Thu May 25, 2006 9:28 pm » Post: #5 » Download Post
I just got me a set od HRC springs for my forks so i think they're not disco'd. I got the p/n from the tuning section. After they were setup right, they feel feckin awesome! Can't go wrong with HRC..
and yes, the racetech springs are a lil too stiff for the lil nsr.
MC21 300R w/SE bits, Rossi 2001
MC28SE Silhouette Repsol
sparky
Thu May 25, 2006 9:33 pm » Post: #6 » Download Post
Johnblaze where did you order the HRC springs from?
I sent Apex Leisure a e-mail and they told me it was discontinued.
sparky
Thu May 25, 2006 9:34 pm » Post: #7 » Download Post
Dave Ett wrote:Surely you want to use a rear shock spring on a rear shock? Front springs look far too long to fit on there! Wink
Yeah might be a better idea for me to use the fork springs on the fork Rolling Eyes
JohnBlaze
Thu May 25, 2006 9:57 pm » Post: #8 » Download Post
[quote]Johnblaze where did you order the HRC springs from?
I sent Apex Leisure a e-mail and they told me it was discontinued[/quote]
I got them from gpcmoto.com .
Fluffy Cat
Thu May 25, 2006 11:04 pm » Post: #9 » Download Post
You could try the hyperpro springs. I used them on my race NSR and they worked very well. No chatter under hard braking.
big pete
Fri May 26, 2006 2:14 am » Post: #10 » Download Post
I'm 180ish and a good suspension tuner in Northern California suggested I go with .80kg/mm springs for the front while the rear spring is good enough for my weight but I should revalve it.
I just got my .80 springs from racetech and will be sending my rear shock to get revalved by Aftershocks Suspension in a few weeks.
1994 NSR250SE
sparky
Fri May 26, 2006 7:05 am » Post: #11 » Download Post
thanks for the info, I'm goign to try a heavier oil and see how it feels first.
Samk
Front Fork
Fri May 26, 2006 4:04 pm » Post: #12 » Download Post
Sparky,
I feel really honor you made that decision.
SamK
90 NSR SP
sparky
Sat May 27, 2006 5:33 am » Post: #13 » Download Post
if it worked for you I don't see I shouldn't give it a try. if it's still too soft I can try changing the springs.
