Electrical Fault - turn/horn fuse blows when hit bumps
zro
Sat Sep 16, 2006 9:26 am » Post: #1 » Download Post
Hi I have an 96 MC28SP.
Everytime I hit some bump my fuse blows so my dashlight/indicators dun work. I stripped the computer/leads, see no visble shorts and used electronic contact cleaner on the connections, could it be my turn relay.?
any help appreciated
Sat Sep 16, 2006 11:21 pm » Post: #2 » Download Post
Tricky one this.
You're going to have to check all the places the wiring loom runs close to the frame, as it's likely that some insulation has worn through and is causing a short.
Personally, I'd disconnect both leads from the battery, then do a continuity test between each pin of the plugs and the chassis to find out which one is causing the short.
