There are 2 types of '18 fly wheel. The'88 R2j used a larger fly wheel than the later '89 R5k and therefore uses a shorter pickup.
The r5k fly wheel though uses the same pick ups as the MC21 and the same dia flywheel but with different ign timming. _________________ If I have to take the carbs off once more...
XXXXX-XXX-000 last three digits indicate various suppliers or improvements on the part. So i assume that the 2 parts MC18 MC21 flywheels are interchangeable. It looks like it is. BUT....
Can someone else confirm me this ? don't want to spend more money on flywheel i wont use.
The '89 MC18 fly wheel is slighty retarded compaired to the Mc21....
However the MC18 runs a shorter barrel and different head volume compaired to the '21 so I would say its safe to fit a '18 fly wheel on a '21 but not a '21 one to a '18 unless you know what your doing. _________________ If I have to take the carbs off once more...
