Tried to start the bike yesterday and it wouldnt go despite starting first kick a couple of days earlier. Have gas and spark so that doesnt seem to be the issue. I do have a "pumping or whirring" type noise coming from beneath the tank when I turn the ignition on.....so I am thinking its the servo motor. Anything to llok for check before I pull the tank off.
its the R/C servo motor making the noises. As soon as the ignition is turned on it starts to 'hunt' for a neutral position but cant find it and just goes back and forth but not a lot. I am assuming the valve is jammed somehow so will be pulling it all apart.
