powervalves mc18
marcus
Guest
powervalves mc18
Sun Sep 12, 2004 5:37 pm » Post: #1 » Download Post
should the servo motor make a noise when the ignition is turned on?because it seems that sometimes the powervalves are not opening could anyone help with this please thanks
Mon Sep 13, 2004 7:22 am » Post: #2 » Download Post
Depends what revs you turned off the engine at.
The valve does not cycle like the RD and TZR used to do, but if the valves were open when you shut off the ignition then the motor will drive them closed for startup.
To check it is working, switch off the igntion, remove the right hand panel and rotate the valves by hand. Switch the ignition back on and the motor will drive the valves closed...
