I was pretty set on reusing the cyl's on this new 21 project, but am a little affraid of building a time bomb.
In both cyl's, you can still see the cross hach(?) pattern almost every where.
Almost cause where the piston rings stop at both ends it barely vissible. Ther are no ridges or flaking either.
Use or not to use? That is the question _________________ MC21
04 NSR50R
93 CBR F2
98 CBR F3 track bike
95 VFR750
89 FL400R Pilot
90 FZR 4/600
OK.... That's a good thing. So do you think I could use the whole set up again if I get the pistons and cyl's measured by a pro and they check out good? Would I ust the rings that were in it? If fitting new rings, do you have to scuff up the walls so they will seat???
I'll still need a fresh crank and all the seals... I've got to figure this out, I'm ready to get some parts and get this thing together !!!! _________________ MC21
04 NSR50R
93 CBR F2
95 VFR750
89 FL400R Pilot
90 FZR 4/600
