powervalves
paul
powervalves
Sun Nov 14, 2004 8:51 am » Post: #1 » Download Post
does anyone have any advice on the best method for removing the valves from the barrel
Mon Nov 15, 2004 7:51 am » Post: #2 » Download Post
Yes.
Take off the exhaust.
Remove the pulley wheel - it's reverse (or left hand) thread, so don't break it trying to get it off the normal way.
Remove the circlip.
Screw the nut and washer back on to the shaft.
Use something to heave on the end of the shaft - I use a claw hammer and rag and lever the thing out.
It may be very hard to remove, but it is simply carbon build up - there's nothing else holding it in there.
Tue Nov 16, 2004 12:19 pm » Post: #3 » Download Post
Go carefully with Dave's method. i'm sure that it works for him, but it's quite easy to bend the shaft, which could cause it to bind up upon reassembly.
There are proper tools available which are no fuss.
