Base gasket question
CircuitR
Wed Jul 09, 2008 5:26 am » Post: #1 » Download Post
Hi guys,
I'm about to put my mix 'n match engine together, I'm now running an MC16 bottom end with MC18 cylinders and heads. My question is, what is the thickness of the base gaskets? As I am going to make these myself.
Blair
Canuck13
Wed Jul 09, 2008 6:39 am » Post: #2 » Download Post
why are you going to make them? The 16 and 18 use the same base gasket. They are not what I would call expensive either. I've a couple at home I can mic for you tonight.
Cheers,
CircuitR
Thu Jul 10, 2008 9:18 am » Post: #3 » Download Post
It's not a case of cost, I wanna get this engine together this weekend and I can't find anyone in NZ who has them, so I would have to get it from Aussie (like everything else). And I would have to wait, I don't do waiting.
Being an engineer means knocking a couple of gaskets up takes no time at all.
If you could mic those gaskets up, that would be awesome.
Did I mention I was putting MC21 pistons in Twisted Evil
Thu Jul 10, 2008 10:00 am » Post: #4 » Download Post
Stock Honda base gaskets are 0.5mm
HRC do(did) .4's and .6's as well.
CircuitR
Fri Jul 11, 2008 3:16 am » Post: #5 » Download Post
Cheers Fontty, you are the man.
Very Happy
Canuck13
Fri Jul 11, 2008 9:16 am » Post: #6 » Download Post
yes thanks fonty, saved me from digging out mine Very Happy
Mon Jul 14, 2008 3:53 pm » Post: #7 » Download Post
It's the "crush" of the OEM gaskets that you need to consider, not the thickness.
They tend to crush a lot less than even the more expensive gasket papers.
For the sake of not wanting to wait for a pair of £3.50 gaskets, you could end up off the road for considerably longer if the pistons melt due to a combination of compression and (possibly) low octane fuel!
If you must make gaskets, I suggest you make them out of 0.6mm, just to be on the safe side. It won't cost you too much performance on a stock motor.
andreb
Mon Jul 14, 2008 9:56 pm » Post: #8 » Download Post
Only a proper Kiwi would make his own base gaskets! Remember this is the country Bert Munroe and John Britten are from. If you don't have it on the island, make it yourself.
Good luck CurcuitR!
May Bert and John be with you...
Andre E. Benguerel
1996 Honda NSR250R
2000 Honda RS250R (NX5)
2008 Honda RS250R (NXA)
AFM Expert #430
