Hey guys
This is just a quick one to all the people using Tyga RSW style lower fairing
1. If using factory rear sets (steps) how did you get around the brake lever fouling on the faring ? I dont want to cut it. I was  just going to bend it a little. Only needs to come out 5mm to clear the faring.
2. Side stand. This is a street bike so i cant remove it. I was thinking of riviting a small stainless plate where it rubs, and just leaving it rub against that, usless there is some 'trick' in moving/bending/adjusting the stand ?
3. Is it normal for the top triple to foul on the upper brace on full lock ? Once again, its not a major problem as your never on full lock when moving anyway, just cusrious.
And, i just want to say thanks to the guys at TYGA PERFORMANCE. I ordered the parts on a friday, and recieved them within 6 working days. And they threw in a free shirt. Very happy with the excellent service !!!
 .i think you have the good option of getting the tyga kit as i bought the rsw not even knowing if it would fit,and my dads face as i butcherd a brand new fairing was priceless
.i think you have the good option of getting the tyga kit as i bought the rsw not even knowing if it would fit,and my dads face as i butcherd a brand new fairing was priceless  .it fit spot on though to be honest i just had to trim more off when put the f3 rad on,and its needs a bit where the huge expansion chamber is on the right hand side
.it fit spot on though to be honest i just had to trim more off when put the f3 rad on,and its needs a bit where the huge expansion chamber is on the right hand side            				 to fit our more western pie eating frames.
