float bowl seals
ricey3
2006 Honda crf450 r
float bowl seals
Fri Feb 27, 2009 5:19 pm » Post: #1 » Download Post
has anyone managed to buy the float bowl seals seperatley? will give allens perf a call in the morning but wiondered if anyone could give me the heads uo.
cheers
brendan
RichG
Fri Feb 27, 2009 5:38 pm » Post: #2 » Download Post
I think I've got quite a few of these spare. I'll double check in the garage & let you know.
Rich
ricey3
2006 Honda crf450 r
Fri Feb 27, 2009 6:28 pm » Post: #3 » Download Post
cool!
bike fired up first prod with the foot tonight but was leaking quite a bit from the float bowls, imagine thay must of gone hard after being sat there just over a month
cheers
brendan
Max szeged
Fri Feb 27, 2009 8:39 pm » Post: #4 » Download Post
sounds more like a float jam... where are they leaking from did you see? my fuel came out of the drain/overflow pipes, maybe you have the same problem.
If the bowls had not being removed or taken off since a month ago i dont see how the seals can cause a fuel leak. but i may be wrong!
better get a flash light and have a good look before... well if this is happening you got to take the carbs off anyway.
good luck!
feel the wind
ricey3
2006 Honda crf450 r
Sat Feb 28, 2009 2:19 am » Post: #5 » Download Post
no i could see it weeping out between the seals on both carbs, no where near the overfloe etc and floats are fine. if you think about it the carbs are of a 92 bike, they are 17 years old.
