MC21 main oil tank problem
Digity8
Sat May 02, 2009 10:48 pm » Post: #1 » Download Post
My main oil tank ( the small plastic one connects to the 2stroke oil filler tank) sprung a hole because the sparkplug was loose and burned a hole in it. Would it be ok to use a JB Weld or epoxy type product on it to seal the hole? The hole is about 1/4 in diameter?
Canuck13
Sat May 02, 2009 10:58 pm » Post: #2 » Download Post
i would be concerned about getting a good bond between the plastic and the epoxy. Why not try a P-tex ski base repair stick and melt new plastic in? Alternatively new tanks are avaliable. I may even have an old one kicking around that your welcome to.
cheers
Digity8
Sat May 02, 2009 11:04 pm » Post: #3 » Download Post
ohh...the hole is in the side so it may be ok, i will look into that ski repair kit, and if you could PM me if you come across an extra one. thanks!
