NC35 Fork set up
lopezji
NC35 Fork set up
Mon Sep 21, 2009 6:51 pm » Post: #1 » Download Post
It's been a while since I've been on the site and I couldnt find anything w/ a search. I did a NC35 RVf 400 USD fork swap onto my 95 MC28 SE and I hate it. I feel like I've lost all confidence on the front end and the bike even feels slower. I took it to New Jersey motorsports park last week and rode around in my brothers R1 the whole time. The NSR never made it past the parking lot. Are there any base settings that anyone can recommend? I'll be going back in October and want to get the bike sorted before I even attempt to bring the NSR. I am almost tempted to swap back to the stock front end. Any help would be appreciated. BTW I am not a suspension person but do know that the oil and springs are in good shape. I purchased the front end from Yack a few years ago. Thanks to all who might chime in.
Hermit
Tue Sep 22, 2009 7:06 am » Post: #2 » Download Post
How much do you weigh?
You should start by setting the 'static sag' which is related to your preload setting. This is altered by turning the big nuts at the top of each fork leg and setting it up to suit your body weight will give a good starting point for setup. Google it to find a step by step guide of how to do it online. You'll need a second man to help you do the measuring. If you have too much preload on at the moment then your front end will not be settling down enough under your body weight when you sit on the bike. This will mean the front end is riding high on the suspension stroke and won't have enough negative travel to cope with hollows in the road surface for example.
A good way of seeing how your suspension is working is to wrap a cable tie around one of your stanchion tubes (the chromed bit). Slide it up so it touches the black dust seal at the bottom of the gold part of the fork leg. Go for a ride, find a good, grippy road surface (if one is available) and simulate how hard you would brake for a corner on a trackday. The cable tie will have slid down the stanchion and will show how far the suspension has been compressing under heavy braking. Mine uses about 80% of the available travel in this situation. If yours isn't moving that far then you may have too much oil in your forks which would be my first guess at this stage.
I've got the same conversion on my MC21. I have the original RVF400 springs in. I'm running 300ml of oil in each leg - which is less than standard. Standard fork oil fill capacity is 445ml per leg.
lopezji
Tue Sep 22, 2009 12:11 pm » Post: #3 » Download Post
Thanks I will start working on it this weekend. I'll keep everyone posted but many Thanks for taking the time to respond.
