mc18 miss tacko jumping help fast
nsrdownunder
1993 Honda nsr 250 mc21 sp
Sat Nov 21, 2009 11:27 pm » Post: #1 » Download Post
Hi got a ride day in a couple of weeks and my mc18 is missing .It has a miss and the tackometre jumps down 1000rpm each time and it does this at any rpm anyone got ideas
Neal
Sun Nov 22, 2009 7:04 am » Post: #2 » Download Post
I had a faulty battery last month and the bike was doing the same as you describe , i hope you get it sorted .
cheers , Neal
nsrdownunder
Sun Nov 22, 2009 7:52 am » Post: #3 » Download Post
i wish it was that easy already tried swapping batteries.
Sun Nov 22, 2009 9:48 am » Post: #4 » Download Post
Check the wires to the coils. They can get carbon build up if the connectors are not tight.
The tacho is driven from the PGM unit (s) so do a careful check of all the connectors, and also do a resistance check of the earth wire (from the battery to the frame, just disconnect the positive lead from the battery before you do it.)
Should be as cole to zero Ohms as possible.
nsrdownunder
Sun Nov 29, 2009 10:08 am » Post: #5 » Download Post
I found the problem the left crank bearing gone Crying or Very sad Crying or Very sad .
So i`ll be seing ****** for a rebuilt one now.
Sun Nov 29, 2009 10:40 am » Post: #6 » Download Post
I'm not saying your crank isn't a problem but there's no way that a bearing problem could cause the tacho to drop 1000 rpm.
nsrdownunder
Sun Nov 29, 2009 11:26 am » Post: #7 » Download Post
Yeh that is the prob . The stator moves about 5mm up and down it is just weird that the bearing was not noisey. I guess the stator kept hitting the pickups or being to far from pickups. Then the pgm did not know when to fire or what the rpm`s were.
RichG
Sun Nov 29, 2009 12:04 pm » Post: #8 » Download Post
I'm surpised it actually ran at all, with a stator deflection of 5mm due to broken crank bearing Shocked
Rich
